cuffuup28 »
https://forums.nicoclub.com/cuffuup28-u62328.html
Fri Jan 11, 2008 7:39 am
This reply is for oc350z...
It depends on what year your Z is. The older it is, the more fragile your paint is going to be. It also depends on if you "rip" them off, or take your time. I have the side Z badges that "blink" when you use your turn signals, (also available at courtesyparts.com) and before I removed the badges, I heated them up with a Hair dryer. The badges are only held on with 3M tape, and if you heat it up first, it melts the glue on the tape, and the badges just "pop" off. You might need to use something to pry off the badges if your car isn't a newer one, but PLEASE make sure it's something plastic, and don't apply too much presure. You can also use some fishing line AFTER the badge is heated up, but your going to have to go AROUND the back of the badge. You can't just go through the middle of the badge due to the alignment prongs.
