My new daily SR setup from turbodave!!!
SILVIADRIFTR
Car: 1993 nissan k's silvia
Dave just got thru with a new daily driver setup. List of mods:
Walboro 255lph fuel pumpHKS 550cc injectors24x12x3 intercooler with blow thru Z32 mafTurbonetics HiFi 60 turboSAFCApexi turbotimerCustom built (by turbodave) longtube top mount manifold and downpipe.
The car put down 304whp/264ftlb tq @11psi!!!!!!!
Modified by SILVIADRIFTR at 11:53 AM 8/3/2005
SILVIADRIFTR
another...
SILVIADRIFTR
one more....
dareo
Car: 1993 Q45, 1989 240sx
looks really nice! Do yourself a favor and heatshield the crap out of your brake booster, lines, wiring, anything near that turbo. a buddy autocrossed w/o shielding and did about 1,000 in dmg melting his harness, the harness shorted out the ECU, the brake fluid boiled, ect on his silvia. Get one of those cool ooking Turbo Blankets for the exhaust side turbine, that should help a lot.
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
that looks really good. congrats on your new setup.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
HOW MUCH?
912.0turbo
did you get the manifold from him too? how much was that manifold? Looks nice!
SILVIADRIFTR
Yes, he did make the manifold and he only charged 900.00 for the manifold. Alot less than the one that looks very similar to it that is offered with the same thickness, materials, ect. I had the z32, front mount(no piping), afc, and injectors. He did everything else installed(including the manifold) for 2200.00. He did the downpipe, removal of all the old turbo setup, new stainless supply and return lines, turbonetics evo wastegate, all intercooler piping and z32 blow thru conversion, and the manifold and install for that price. Best deal I have seen for all that.
Also, I have the heat shield for the turbo and the turbo blanket for the Brake master cylinder and resevior. Also got the heat wrap for the harness, just haven't gotten pictures with it on yet.
Sirk
Car: 97 Maxima SE 5SPD
Hell yeah man, that thing is bad!
Cyberkreig
Car: 1993 Nissan 240SX SR
How is that Blow Through setup workin for you? Any special tuning or setup (aside from the positioning obviously)
SILVIADRIFTR
Cyberkreig wrote:How is that Blow Through setup workin for you? Any special tuning or setup (aside from the positioning obviously)
When I was running a blow thru on the silvia I didn't have any problems and actually less problems ms because it would die after falling back to idle after a full pull.
An update for you. After replacing the trans due to shattering first and second gear and finding a loose ignition connection the car did this at 13psi.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
Looks good. Are you the white or Black Silvia I saw a Daves shop.
SILVIADRIFTR
sean8564 wrote:Looks good. Are you the white or Black Silvia I saw a Daves shop.
I have the black silvia.
sean8564
1993 Nissan Silvia
Ok the on Eric put the 300zx transmission in.
SILVIADRIFTR
sean8564 wrote:Ok the on Eric put the 300zx transmission in.
You mean Eric @ E&E???I hope Eric didn't tell you he did that 300z trans, because he had nothing to do with that. Turbodave does all the work on my car and Eric doesn't know how to tig aluminum or make driveshafts,ect.. Did Eric tell you this, or is that just what you heard?????
Modified by SILVIADRIFTR at 12:04 PM 8/5/2005
sean8564
1993 Nissan Silvia
I saw him working on it when he was at daves shop about a year ago.
IH8URDSM
I live in Atlanta now....someone that knows me from the old skool has to hit me up! [email protected]
Rollhard.comRPI
SILVIADRIFTR
sean8564 wrote:I saw him working on it when he was at daves shop about a year ago.
Not on my car. Eric has never worked on my silvia. And it has been the only black one up there.
sean8564
1993 Nissan Silvia
yeah when eric was at daves shop he was working on it about Nov-jan time frame. when voya was doing his 26 swap.
SILVIADRIFTR
sean8564 wrote:yeah when eric was at daves shop he was working on it about Nov-jan time frame. when voya was doing his 26 swap.
The trans was in the car in late september(right after nopi nationals). Eric has not ever worked on my car. He may have been at Dave's shop at the time but he wasn't working on the trans.
sean8564
1993 Nissan Silvia
I will post up pic then I took of you car when Eric wasa there and him working on the 300zx transmission in the black silvia with triple beam projectors from Dville. because i thought i was cool that there was a real silvia. this was a turbo daves shop. when he was on Frank akin Rd.
SILVIADRIFTR
sean8564 wrote:I will post up pic then I took of you car when Eric wasa there and him working on the 300zx transmission in the black silvia with triple beam projectors from Dville. because i thought i was cool that there was a real silvia. this was a turbo daves shop. when he was on Frank akin Rd.
Are you sure you're not referring to voya's right hand converted old coupe that Ryno has now?? Go ahead and post this pic you have. I would like to see it. Here are my pics....this is Dave welding the adaptor to the trans.
SILVIADRIFTR
here it is after me and Dave put it into the car...
driftjunke
Easy Brian, calm down, not me Sean, I never touched Brians car, all Dave on that one.
E
USsil80
soo they put a 300z trannie in a sr 240... more details please
SILVIADRIFTR
Sorry
driftjunke wrote:Easy Brian, calm down, not me Sean, I never touched Brians car, all Dave on that one.
E
ric, nothing against you but the guy just wouldn't listen.
SILVIADRIFTR
USsil80 wrote:soo they put a 300z trannie in a sr 240... more details please
What kind of details are you looking for? The tranmission belhousing has t be modified with an adaptor plate and it still retains the sr clutch, flywheel, tob, and slave cylinder. Shifter mount, driveshaft and trans mounts have to be modified. Dave normally charges 2200.00 with 300z trans and all hardware and labor to do that setup.
USsil80
does the shifter move-ie just change places where shifter is- or do u fab something up to move it....what happens gearing wise in the car.... stupid short first gear or something like that..thanks
SILVIADRIFTR
USsil80 wrote:does the shifter move-ie just change places where shifter is- or do u fab something up to move it....what happens gearing wise in the car.... stupid short first gear or something like that..thanks
The 300z trans has the same gearing as the ka/sr/rb20 but the shafts in the trans are about 3x larger than the ka/sr/rb20. The factory shifter linkage and perch are modified to work with the 240/silvia. I have made numerous runs with the 300z trans and the car is a daily driver as well.
