My new coupe pics (suspension)
veilside180sx
The E already has 8.6:1 compression, so no need there. I'll wait to install the forgies in my spare for anything else in the bottom end.
It's the JGS 24x12x2.75 core size. I had Lance make me smaller endtanks to make it an easier fit. Well Lance said everyone has loved the wastegate and bov, I talk to him almost every day.=) He makes good products and knows his stuff. Same for SPL. I promote products for those that I trust their products, and I stick with those companies as much as I can, or try to anyway.
veilside180sx
As far as alignment, we haven't decided yet. My buddy works at an alignment shop, so we have a Hunter machine to dial in whatever we want. I've been discussing this with Mike Kojima, but still haven't made a descision. jump that hurdle when I get there I guess. Also will have to make adjustments on how it feels.
veilside180sx
Eddiec, I received the control arms back from the powerdercoaters, I'll post pics tomorrow for you.
veilside180sx
I was hoping to get the digital camera to snap pics of the control arms, but can't where my Dad hid it at his house. I'll get to that later I guess.
I purchased SPL aluminum subframe bushings to replace the ES bushings, because my nephew helped me misplace the bottom half of one of them. Oh well what's another $170.=)
Golden
As your system will utilize charge-pressure increases driving journal-bearing stress upon power stroke beyond those of top and botton dead center, I think a discussion of friction hardware would be enlightening. (literary lube to keep from rubbing the wrong way)
R240sx
Car: 1990 Nissan 240sx
Wow, that is looking VERY NICE!!!
Good job on the work man, i could only dream of having HALF of that stuff!!
veilside180sx
R240sx wrote:Wow, that is looking VERY NICE!!!
Thanks
Also intercooler piping was finished yesterday, took me awhile but I did it. Kuah shipped the SPL bushings out so they will be here on Thursday and installed on Friday. So the rear suspension will finally be installed on Friday. Woohoo. After that it's time to start wiring up some stuff.
SmithSR
Car: 240sx
Wow.. just looked over page 1 & 2 Wow!I'm genuinely impressed by the work.
veilside180sx
Thanks SR I respect your opinion.=)
skylndrftr
Car: 07 Nissan Versa S
2010 Ariel Atom (pending...)
to go along with the powdercoating disucssion...anyone ever done anything stronger like the bed coating junk on arms? I live up north where rust is life and was considering haveing some of my components sprayed with rhino lining before installing them
veilside180sx
The ball joints are installed in the lower control arms woohooo. Long dilemna for both my buddy and myself in dealing with the auto parts store that coudln't seem to get it right.
I'll snap pics of that stuff on Friday, when I install them. Along with the whole subframe (including the new SPL solid subframe bushings).
veilside180sx
All the rear suspension is installed. As well as the wheels. It's ready to be dropped on the ground with the exception of us breaking 2 jacks in the process. Should be running in the next 2 weeks if all goes well.
Have pics but accidently burned the wrong ones on the cd that I burned. So I'll post those later this weekend.
veilside180sx
Intercooler piping is finished. It's not the prettiest thing but it'll work for the time being. After playing with aluminum I'll replace it in the long run anyway, because I cheaped out and bought mild steel. I still need to do the downpipe and wastegate dump though, so that's next on the fabrication agenda.
I managed to misplace my rear brakes unfortunately, so I'll track down a set of those from the junkyard this week as well. (to tide me over until I use a set of 300zx ones)
Hopefully we'll get the AEM wired up this week or the following and I can finally start up the car. Woot.
veilside180sx
Passenger Side Shot
Drivers Side Shot
Engine Bay Pic
tm_kickz
veilside180sx
Ordered a vacuum block to split for the brake booster, fpr, map sensor. Then I'm just going to use a T fitting up front for the throttle body and bov.
Also ordered a 90 degree coupler going between the turbo outlet and the intercooler piping, dang those things aren't cheap. The piping I had wasn't a tight enough radius to do w/o putting it up against the fender wall. Which I didn't like how it looked. So I'll actually install the piping Friday after that shows up.
When that's complete it's time to install and wire up the new sensors for the AEM. Map, IAT, Knock, and the gauges.(Boost/Oil Pressure for now)
Eventually I'll go through my harness and remove all the useless junk that I no longer need since I've removed so many sensors and stuff. Don't have the time or patience to tackle that right now though. I'll do that when I go through all the hassle of installing a roll cage.
Also when all this comes to fruition I'm going to setup a touchscreen to view/change my AEM's settings so I don't have to carry a laptop with me. It'll replace the current gauge cluster similar to the MOTEC. Although it will be color and capable of playing DVD's, etc.
veilside180sx
Vacuum block showed up, along with the 90 degree coupler today. So I can finally clear coat the intake manifold and get everything installed for real, permanently. I'll get all the sensors plugged in today and wire up all the basic accessories, but not the AEM yet.The intercooler piping can be hooked up permanently too, had to switch bumper supports so I have to reweld the intercooler mounts too.
I'm also going to pick up a half gallon of PPG paint to spray the front end. Which will be really nice to have done too.
veilside180sx
FMIC Front Shot
Hot side piping
Cold Side piping
crzycav86
Car: 93 Nissan 240SX KAT
Droolzz.. Cleanest setup ever.
What do you do for a living? ..if you don't mind me asking.
veilside180sx
crzycav86 wrote:Droolzz.. Cleanest setup ever.
Thanks
I work at a bank, working a normal job like anyone else. I just save and do the things I want, the way I want to.=)
tm_kickz
T-Bolts smart choice
veilside180sx
Yup it's the only way to go.
I bought a Z32 TT master cylinder, to fill the void left by the stock one. Eventually I'll pick up a set of Z32 rear brakes as well, but not for awhile now.
veilside180sx
Some pics of what I installed today.
I also bled the brakes today. Will be very nice to have good fluid and brakes.
veilside180sx
Here's a pic on the ground. Crappy pic, but will give an idea of ride height.
veilside180sx
Well I did the unbelievable today. I purchased a GP Sports G Sonic Replica kit today. I wouldn't of purchased a copy if I didn't know I would wind up trashing it or something. We'll see how well it fits when I get a chance to put it on...
Will take pics later as well.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Very sweet setup, keep up the good work!
-Dan
veilside180sx
Thanks.=)
sensibleS13driver
thats the way to do it, everything new and clean, that car will be sweet when its done, keep us posted!
veilside180sx
I was working on fitting the skirts yesterday. Body kits are a pain to install.=) Now I know why I've avoided them thus far. It'll look good when it's done though. I have to admit I'm much better at motor work than body work though. haha.
veilside180sx
Side shot with the side skirt placed on, but not permanently mounted.
