Well, I've made some progress on determining why in the heck this car is so doggone slow! Something ain't right with the transmission. When I first bought it, the trans was shifting crisply, but the car was slow.
Now I've determined that if I'm easy on the throttle, the trans will shift through all gears. If I give anything beyond 15% throttle to 100% throttle, the car will skip, surge, and bog its way down to almost a halt. I literally struggled earlier tonight to go 40 mph's for a few minutes before it kind of hiccupped its way through it and alternated between normal throttle response and grinding to a halt.
It was rrrreally bad the past two days. Yesterday, I don't think it wanted any parts of the 2-3 upshift while I hopped on the freeway onramp. It was willing to get up to about 40mph, but did not want to get me from 40 to 65. I had to be delicate on the throttle to fight through the slowness before it shifted from 2nd to 3rd or skipped 3rd to go from 2-4. Tonight there was a few moments where it didn't want to give me 3rd OR 4th while climbing a hill, until I realized how I could only give the throttle like 10% or else it would bog and rev itself to a halt.
Another thing I noticed, is that I hear a popping noise and feel an intermittent tap from the engine bay as the trans and engine skips the car forward--but only if I give the throttle some 50% pressure or more. I thought it was a misfiring problem, but the speedo gauge going wacko tells me that something is wrong with the VSS. I just don't quite know why everything is going wacko at the same time (unless the ECM is failing).
I'm hoping (praying) it is the VSS (vehicle speed sensor) and nothing more. But because I'm not an expert with Q's, perhaps you guys know better.
I'd like to post 5 videos of my problems:
http://smg.photobucket.com/alb...9.flv
http://smg.photobucket.com/alb...8.flv
This is how long it takes for me to accelerate (0-60). This was the fastest I could get the car to accelerate:
http://smg.photobucket.com/alb...0.flv
http://smg.photobucket.com/alb...1.flv
http://smg.photobucket.com/alb...7.flv
Modified by Lakeshow24 at 2:58 AM 12/23/2007
Modified by Lakeshow24 at 3:03 AM 12/23/2007
