semi-fly wrote:fine, ignore the advice from the person that was having THE EXACT SAME PROBLEM.
Dude... Chill much???
Where do you get the impression I'm ignoring you? I read your advice and I'll look at the tank. If I'm having a rust issue though I'd think it would either shut down the truck completely or randomly choke out, neither of which are happening.
Instead it only drops RPMS exactly 3 minutes into idle which sounds like a carb stage problem so I was ALSO looking for some carb adjustment advice.
You seriously must be the most insecure person on the Internet.
