Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Tue Jun 15, 2004 9:13 pm
See the 240sx.org , Faq section on reading trouble codes. It might help you figure out what is triggering the code to turn on your " Check Engine Light". As far as reseting it once you have finished unless you follow the procures for reading codes, it will likely stay illuminated for 50 ignition cycles unless there is a major problem. good luck
