my new 180mph converted speedo
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
well i found the write up on how to convert the jdm 180kmh speedo to 180mph ( nicoclub.com ) and let you know it is about i say 95-100% accurate for me heres the installed pic
Shocker
Car: 89 240sxHB rb26/30
nice work, no file off the kph and stensile in some mph
BoostFab
Car: S13cp, S13fb, S14z
i converted mine last year and benchmark the speedometer to my gps unit and it was on the dot. the odometer is a bit off however.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
yea the odometer is off according to the writeup its 5.7% high but other then that since ls auto doesnt make one for s14's so i just went this route. im swapping out the lights bulbs in my cluster with red led's once they come in the mail.
m tr4nch
Car: RS13, Z31, P11
HxC_Nismo wrote:yea the odometer is off according to the writeup its 5.7% high
i've been wondering about that for a while now. so after an RB swap, the odometer starts counting in km? does that have to do with the speed sensor for the RB transmission or something? any way to correct that to read in miles again?
Cjmartz2k
Car: Hunting for a '89 GTR now
So I wonder, I've got a 260kph speedometer in the skyline. If I ever get this thing back to the states, could I convert it too?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
no on the s14 speedo it reads in mph with no issue as long as you have the stock 4.08 gears in the back on the s13 im not sure on what needs to be done in order to work with the rb but im sure the http://www.lsauto.com has a speedo and tach for an s13 that will work with an rb
Cameron
Car: a 240
Cjmartz2k wrote:So I wonder, I've got a 260kph speedometer in the skyline. If I ever get this thing back to the states, could I convert it too?
260MPh FTWINZORZZZ
m tr4nch
Car: RS13, Z31, P11
HxC_Nismo wrote:no on the s14 speedo it reads in mph with no issue as long as you have the stock 4.08 gears in the back on the s13 im not sure on what needs to be done in order to work with the rb but im sure the http://www.lsauto.com has a speedo and tach for an s13 that will work with an rb
yes i'm aware of that. i was talking about the odometer counting in kilometers instead of miles, not the speedometer/tach.. any ideas?
BoostFab
the odometer will be 5% faster.
BoostFab
i just converted another one for a friend yesterday; spedometer exactly on
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
BoostsFed wrote:the odometer will be 5% faster.
+1 he is right
alex4
Car: 89 coupe, 87 supra
I just put the GPS in the car. It's within +/- 1mph of my speedo. It doesn't work in tunnels though...just don't go over 110 anywhere you can't get satellite signal.
BoostFab
alex4 wrote:I just put the GPS in the car. It's within +/- 1mph of my speedo. It doesn't work in tunnels though...just don't go over 110 anywhere you can't get satellite signal.
and
alex4
How hard is it to put in different color lights behind the cluster? I'd love some red cluster lights
BoostFab
alex4 wrote:How hard is it to put in different color lights behind the cluster? I'd love some red cluster lights
pretty simple; they have bulbs that plugs into the back, you just change the jacket on the bulb.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
http://www.superbrightleds.com you want the wedge 194 you need 4 of emheres the writuphttp://www.s-chassis.com/forum...40228
BoostFab
those lights are pretty cool
S14eva1
Car: S14 aka "The black bandit"
anyone tested that 180mph speedo on the road yet.....
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
i have but i only took it up to around 150mph range i still have stock suspension and 16" wheels with tall sidewall bfg tires so i try not to push it
BoostFab
S14eva1 wrote:anyone tested that 180mph speedo on the road yet.....
i did the 180mph pull at the Bonneville Salt Flats
Cjmartz2k
Do you know if it's the same for a R32?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
there is a few write ups on skylinedownunder.com or some british skyline sites have it cause i ran across a few but after doing it to a skyline it will effect your hicas system so look into it before attempting to mod it.
gawdzilla
Car: none
Cjmartz2k wrote:Do you know if it's the same for a R32?
i think some if not all R32 have cable driven speedos...
