cruzad3r »
https://forums.nicoclub.com/cruzad3r-u155549.html
Tue Apr 27, 2010 7:40 pm
so i'm guessing you're out of warranty period and you don't have the Elite extension. well, my suggestion is as follow: first there's the nite/day button that you can turn the screen on and off. if that works, well great. turn the dam thing off before you turn off the car. if that doesnt work, go scout the internet for a new controller board; the a/c controller and the round dial part from either yunkyard or ebay and swap it in. you can also try to do the diagnostic on board by holding setting and turn the volume knob either direction 40+ clicks. hopefully that will give you some sort of trouble code. if you have cipher cable or know someone has one, try to scan your car for codes. we're basically going in blind here. there isn't any other info except "it happened one day out of thin air"
either way you look at this, it'll be expensive and time consuming. so if you ever end up with a solution other than take it to the dealer, make sure you document it and share it with other M-owners. good luck man
