Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Wed Nov 03, 2004 11:55 am
i keep my car in lower gears, to save the transmission from "chugging". I usually shift through all 4 gears, manually, at normal RPM's )it is fun to use the shifter). I also bump the car into Neutral at most red lights, to save the transmission from heating up needlessly. If I can, I'll bump the car into neutral, and coast to the stopped traffic. I always bump it into neutral at drive-thru's, down hills, on the interstate sometimes, and in stop-and-go traffic. I coast about 2 to 3 miles everyday, on my daily commute of 138 miles.
I use the motor to slow the car down, on steep hills, to save brakes.
I try to use 3rd as much as possible, but the car still hesitates, and jerks where it usually shifts into 4th, so I usually shift into 4th or slow down a bit.
My brakes still only last about 20,000 to 30,000 miles, my transmission will probably only last about 150,000 miles (it is at 105,000 right now - second one), and my gas mileage is about the same, no matter what I do, as long as I dont drive it like a Mustang.
I agree with Dennis, on longetivity of transmission, tires, and brakes are more important than gas mileage.In the long run, you just can't save enough gas, to make up the difference.
