MikeDombeck wrote:my tuner has them... all i have is the dyno sheet... its not the maf, no leaks, and plugs are perfect... i just wish i could explain what it looked like on the computer screen, the car would rev normal, but the ecu is reading all over the chart like im going from 1k to 8k to 5k to 3k to 7k at all percentages of throttle while im climbing up my rpm's... so its throwing the fuel for what it is reading i believe and thats what i think is causing it.
I know nothing about greddy emanage but I do know apexi power fc --- there are different systems for different gen sr20s there are about 4 or 5 different ecus made for each series of sr20det. That is what comes to mind that it is either wiring into the ecu causing it get messed up readings or the ecu is jacked. Verify the series of sr20det you have and make sure it corresponds to the correct ecu you have.
