My motor Build
hugogos22
Ok lets start a couple of months ago i upgraded my turbo , quick list Greddy down pipe, testpipe, apexi n1,greddy hot pipe , mr manifold, greddy turbo extension, earls turbo lines , gt2871r gtrs, greddy intake, z32 mass air, greddy m spec intercooler, greddy e01, RS enth rom tune . The car ran crazy strong for like seven hours ,then piston number three went .I bought a spare shortblock dropped it in. So every body usually goes topmount i want to do something a little different . I want to add a greddy manifold and cold pipe tomei 260 cams valve spring Retainer valves from super tech and eagle rods and cp pistons . and a 50 or 75 shot of the old columbian bam bam Im rebuilding the motor my self i already have my parts list new oil pump bearings etc etc . What would you guys change ? And do you guys know any good machine shops down here in South florida?
T-rev
why did you lose a piston? need to find out what happened before it happens again on expensive pistons
hugogos22
Yeah i was running my t25 at 16 psi for a year untuned.I imagine it was running lean before i got my aem afr gauge.
T-rev
that sounds like an awesome build. Any particular reason you went with eagle rods as opposed re-using the stockers? I thought the stock rods were solid for 400+ hp
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
T-rev wrote:that sounds like an awesome build. Any particular reason you went with eagle rods as opposed re-using the stockers? I thought the stock rods were solid for 400+ hp
pretty sure the rods are good for 400 hp but eagle rods are the **** especially if he went with H beams and not I beams.
hugogos22
There heavy and for the price of fitting them with arp bolt + machine work i just rather go with eagle.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Sounds pretty good. As far as machine shops in FL go pretty much the supreme SR building, machining, and tuning shop in the US, Mazworx is there.
http://www.mazworx.com
hugogos22
Mazworx is the **** they are the best at what they do the only problem they want to charge me close two 3000.00 in machine work for the block alone. But i will be ordering most of my parts through them good people over there.
