My monster fuel system... I hope?
Beanstalk
Car: 89 240sx & 95 240sx
I have twin walbro hp's and a kenne bell boost-a-pump. The specs say that it should flow 600+lph @ 60psi. If my calcs are correct I should have no prob flowing enough fuel for 850whp. Tell me if anyone has an oppinion on this? The carrol shelby super snake makes 725whp with stock twins. It all cost maybe 400ish. I just want to give it a shot.
240z4u
Car: '95 Nissan 240SX
What sizes hard lines are you running to the engine bay and back? Don't even bother running soft lines from the tank to the trunk if you want to meet NHRA standards (which is kinda dumb to me).
StricNyne
i am looking at bosch fuel pump setup, running full voltage to pump, and depending on regulator to hold it at bay, i was looking at 044 and 023 fuel pump, for right now, i have an from reg to rail, but i wanna go AN from pump to a surge to reg to rail with 044 from sump and 023 from fuel tank
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
i want to run a 3liter fuel surge tank with my intank walboro feeding that and run dual bosche 044 -6an dual feed lines and -6 return for my new setup cause im aiming for 800hp for my new setup
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Ive heard the Boost A Pump overloads the fuel pump and kills it rather quick. Any truth to this?
Beanstalk
DrifterProdigy85 wrote:Ive heard the Boost A Pump overloads the fuel pump and kills it rather quick. Any truth to this?
I hear no ...as per k. bell's site that it cant hurt them cuz it has a built in voltage regulator and it wont kick them on unless it hits 5psi
Beanstalk
240z4u wrote:What sizes hard lines are you running to the engine bay and back? Don't even bother running soft lines from the tank to the trunk if you want to meet NHRA standards (which is kinda dumb to me).
I'm running 5/8 feed and 1/2 return ... and soft for now
monkeyballs
im running twin in tank 255s with stock lines....
nissandrftr88
Car: 34 240'S, 3 rx7's, 06 & 07 gsxr 1000
Overkill much??
My friends s14 with na-t 2jz make 780whp on stock lines and a z32 tt fuel pump
DETurbine
Car: Nissan S13 RB25
Twin pumps are always a risk. Had a friend run twin Walbro's on his setup and near blew his motor from one faulty pump going bad. At least with a single pump setup, if it goes bad it simply means the car shuts down, one a twin setup, if one goes bad as the other stays up, you run the risk of leaning out and frying you motor.
Chaos the Xile
Car: 1974 Datsun 260Z
yeah i'm not a fan of 2 fuel pumps, just seems like there is that ONE more thing that can go wrong and i would hate to have my car running off of two pumps and one of them to go out... bad newsmy fuel setup is:
aeromotive a1000 pumpaeromotive compact fprprecision 1000cc inj.greddy fuel rail-10a/n feed-8a/n return12 rci fuel cell
nissandrftr88
DETurbine wrote: twin Walbro's
found his problem...if had been running 2 044's it wouldnt have happened.
i'll be running a aeromotive eliminator fuel pump with -10 and -6 lines with a seperate fuel system for my nitrous with a 044 pumping it.
DETurbine
Can happen to any twin setup. Safer to just run a larger single pump.
Chaos the Xile
my thoughts exactly
DrifterProdigy85
Supra guys seem to have great luck with running 2-3 Walbros or Densos in the tank. Personally id like to use the Walbro pump to a Sump and then run a Aeromotive or Weldon pump as the main feed for the engine.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
I have been kicking around just running 044 submersed in tank for stock RB setup. That should be adequate for later upgrades, don't you think?
I have seen some pretty elaborate fuel setups and wonder if it is really necessary? I would like to think a simple single fuel pump - filter - return system would be more reliable.
