nicku wrote:so you were saying that change the cams and the valve springs will add boost, too???
no, it will not add boost. It will help you spool a little faster and have a higher hp figure (15ish with stock manifold).
Things you need to do now, metal headgasket and ARP head studs. Don't gamble a new motor on old headstuds they are designed to stretch when torqued ONCE and once only.
Things you should do for added power. MAF Upgrade, Bigger injectors, aftermarket exhaust manifold, and either a ROM tune or a piggyback fuel computer.
