Introducing my 1990 240sx:
When i first brought the car home. 296,000 miles, original ka24e, original 5 speed transmission. This car was a ricer rescue. i ripped the giant a** wing off before i took the pictures.
The suspension was toast. Only thing that was good on the car was the coilovers. they only had 1000 miles on them. So i replaced all the bushings with brand new oem units, and added some Suspension Techniques sway bars, circuit sports tension rods and rear upper control arms.
After that, i ordered the kouki tailights
Next up came the motor swap. this was a pain in the a** because i had a friend who was helping me with the swap ditch me. the car sat for about 5 months until all the issues were solved. The OEM turbo was blown, so i replaced that with a new OEM unit. The oil pan was dented and the pickup was crushed, so i had to fix that. Thankfully when i moved up here i ran into a true nissan guru and he helped me finish everything. Now i drive it every other day!
When we pulled the ka out
SR20det installed
Blown Turbo
Final result after eveything was fixed
And now, the car as it sits right now
Basically a run down of whats been installed...
s13 redtop sr20
Miata battery
Megan racing motor mounts
Megan racing transmission mounts
Spec street clutch
s14 oil pickup(thanks to whoever did the how-to on this, i owe ya a beer!)
Cxracing FMIC
CXracing Radiator
CXracing cat-less Downpipe
HKS SSQV Blow off valve
Apexi N1 exhaust
Frsport turbo elbow
Isis intake
Isis power steering lines
Circuit sports coolant tank
Prosport boost and oil pressure gauges
Megan track series coil-overs
Suspension techniques sway pars
Circuit sports RUCA's
Circuit sports tension rods
Wiper-less hatch swap
Kouki tails
17" xxr wheels w/ bridgestone potenzas
Pignose lip
Ill post some new and better pictures once the weather clears a bit. Thanks again everyone!
