You have to replace the stud. it's not that bad. No special tools required.30bino09 wrote:94 Q45
hey guys took my car to Big O Tires for new tires and they over torqued my lug nut and broke my lug bolt. I discovered this sunday when i was replacing my brake pads. I opened the wheel cap put my wrench on the nut and it fell to the ground with a piece of the bold lodged in it. They are denying of course so what are my options for replacing/fixing the problem.
The above does NOTHING to prevent wheel stud from over stretching and breaking from massive over-tightening common with air tool usage. Hand tighten only using a torque wrench to prevent this issue.Skibane wrote:It's a common problem on Qs.
You can prevent it from happening again by removing the wheel and putting a tiny little bit of Permatex Anti-Seize compound on the threads of each lug. You only want it on the threads - the part of each lug nut that tightens against the wheel must remain dry, so that it has enough "grip" to keep the nut from loosening over time.
Of course the shop is going to deny the accusation, But the point is you were never witness to see every time the wheel was taken off and put back on, Was it put on by hand (Torque wrench) or the fast way (Air wrench).30bino09 wrote:94 Q45
hey guys took my car to Big O Tires for new tires and they over torqued my lug nut and broke my lug bolt. I discovered this Sunday when i was replacing my brake pads. I opened the wheel cap put my wrench on the nut and it fell to the ground with a piece of the bold lodged in it. They are denying of course so what are my options for replacing/fixing the problem.
Well always in a shop there is the right way (The sometimes slow way) and a wrong way (The usually fast way). And in crappy shops or dealer they usually choose the wrong and fast way to work on car.qship96 wrote:
I've had a broken stud on my car for about a year now...completely forgot until I reread this thread! Should probably do that when it warms up a bit...Trumpkin wrote:All points are certainly true, But lets face it it is common and maybe even considered wear and tear. These cars are getting pretty old. Thats a lot of on and off of the lug nuts!Chain stores can be rough, independants maybe a better option when it comes to simple stuff. The guys at our local "tire mart" still have pimples!
Livin' on the edge!qship96 wrote:WOW!
if 19 out of 20 lugnuts is living on the edge, then I should really quit the "over the edge" facets of my life!Trumpkin wrote:Livin' on the edge!
