I dont usually post too much on Nico. I am mainly on silviav8 but I figured I would go ahead and put a thread up here too. This is still a work in process but I have made quite a bit of progress with it.
This is the car I started with. 89 S13 MT Non abs open diff. I picked it up for $500 and drive it an hour to my house. I noticed when I bought it that the crank pulley was wobling but it made it home.
My original plan was to rebuild the stock engine and then move on to the suspension, brakes. exhaust etc. and finally swapping in an SR20DET.
Interior gutted
Started to just clean up engine bay...ended up taking every thing out. I am changing the color to Black paint code G10. Painted Engine BayI did rebuild the stock engine(waste of time) I couldn't bring myself to put it in the car. I wanted something different so I sold it.
I did some research and decied on the LS1 swap.
LS1 and T56 6 speed transmission from 2004 Pontiac GTO with 30k
I used Hinson Supercars for just about everything for the swap.
Crossmember Modified. Triangle pieces are half of the engine mounts.
After going in and out with the engine and transmission about a half dozen times I finally got it to fit like I wanted. Had to beat up the tunnel a bit and finally ended up cutting out a section(a bit more than I needed) of the trans. tunnel. The other half of th engine mounts.Transmission mount/brace and aluminum driveshaft
Made a bracket in order to use the S13 throttle cableFuel Pressure RegulatorHigh flow fuel filter mounted underneath car around backseat area.
Hinson Headers
Hole that was cut(I went a bit overboard)
Subframe and powerbrace (tension rod mount brackets) are dropped one ich with aluminum spacers. The kit did not come with anything for the column to reach the rack so I had this made.
Power Steering Line Supplierd by PXDrift. It mates the LS1 pump to the 240 Rack.Willwood Clutch Master Cylinder, Hinson Clutch line and custom remote slave cylinder bleeder.Hinson Radiator and HosesCamaro aftermarket shifter fits in stock location pretty goodHinson Cold Air intakeBottle in the background is a temporary overflow tank.Battery and fuse boxes relocated to the trunk. Its ugly now but I will be cleaning it all up so it looks decent.GTO Ecu ended up in stock 240 location but is too big to fit behind trim panelMade a harness to relocate ecu to trunk as well. This was a pain in the a&*.Oil pan is close to stock sway bar
While waiting on parts to show up I did the Z32 brake swap thing with Z32 master cylinder and booster and PDM brake conversion lines, 5 lug conversion front and rear, 5 Zigen FN01RC 17x8 on front 17x9 on rear.
BeforeAfterYou can see the subframe spacers in this picture.This is the body kit I will be mounting up soon. Vertex...version 1..I think.
Some other things I have done but just got lazy with the pictures:Stance AL+Pro coiloversEnergy Suspension Bushing KitSolid aluminum Subframe Bushings.Roll Center Front Ball JointsSentra Ball joints in rear lower control armsNismo Power BraceNismo 1.5 Way LSD DiffMegan Tension RodsCiruit Sports Outer Tie Rod endsTein Inner Tie Rod endsAnd Probably a few other things I have forgotten...
Here are a couple quick start up videos too.
http://www.youtube.com/watch?v=BICOiHDcYMk
http://www.youtube.com/watch?v=FF6PS_EzTXI
http://www.youtube.com/watch?v=BAH3xTPtDDY
Well thats about it for now.
