My "little" summer build thread
CRyan
Car: 1997 Nissan 240SX
Hey guys - As most know, I've got an S14 SR in my kouki. Yada yada, primarily stock. Well that "boost bug" has bitten me after I took a drive in a friends Supra. SO. Here's my little build for the summer, just to keep me busy. Honestly, I think it would just be considered "bolt on's" seeing as I'm not pulling the engine for anything, or "building it up" to handle gobs of horsepower.
Basically, what I was thinking is maybe 250-275 HP with capabilities of 300. MAYBE 300.
So, what I'm looking at to produce this power? 12 PSI on stock T-28.
I figured, with the many subaru's in this town, I could find a set of injectors relatively quickly. A Z32 MAF to give me air/fuel chart I need, and a tune either VIA standalone or ECU from Jim Wolfe. And yes, I do plan to go front mount, and at 12 PSI have to most likely rid my recirculation valve :(.
Anything else I may need to add to this list, or if you can just give me a guess at what THIS list would make, that'd be great. Thanks guys!
Corey aka CRyan
240_SeX
Car: 1992 240SX SE
you should be able to make 250 on the stock s14 sr with a boost controller and exhaust...
i'm assuming thats not enough for you haha. with what you have listed, and really pushing the T-28 you might be able to hit a little over 300. i've seen it done, but i'm not convinced on the safety of the setups.
CRyan
Thanks for the info.
So I assume your saying 12 psi is pushing that T28 a little far? Isn't the Garret model the GT28## (don't remember numbers)? 250 would be plenty, ideal would be 275.
Also, my wastegate (HKS) has an adjustment, seeing as I have that - do I necessarily need a boost controller?
While I'm thinking about it, I've got a "makeshift" boost gauge. Anybody heard of PLX (?) gauges?
240_SeX
Car: 1992 240SX SE
12 psi isn't pushing the T-28 at all, i run 18-21 with mine. you dont want to run that much without injectors and such.
You'll still need a boost controller.
thoughtless
Car: 1997 silvermoss 240sx SE
wow, 18-21psi on a t-28?!
ray666
Car: '92 240 sr powered tuned with a neo
wow! 18psi max thats what i would run on my s15 turbo but normally kept it 15.
thoughtless
t-28 is out of efficiency @ ~15psi
ray666
i dont think so... when i had it at 18 the mutha f*** would scat. now a s14 t28 at 15psi would be much
