Carl H wrote:nissans use a hotwire maf which works on the principal of resistance increasing with heat.the ecu powers the maf and an internal wire heats up and as air passes over it, the wire cools and causes voltage to increase.because of this ambient air is 'measured' while the maf reading is taken.
I know how the MAF works...
This is my issue, and it's not with you, it's just in general.
GM and Ford use very similar MAFs as Nissan. 0-5V Hot Wire sensors. GM and Ford also use a separate Intake Air Temp Sensor in conjenction to the MAFS. Why? To allow for additional correction for extremely hot and cold climates and to verify the MAF accuracy.
90* air flowing through the MAF at X velocity will cool the hot wire Y degrees, and 40* air moving through the MAF an a velocity <X will also cool the air to the same Y degrees. You would like to think that the lower velocity cooler air (read lower CFM) would have the same Mass Flow Rate (read lb/min) as the higher velocity warmer air, but I'm not sure that's an accurate assumption. I could be wrong, but I just can't wrap my head around it right now.
On the Karman Vortex sensors typically found in Mitsu's the actualy air velocity is measured, the Baro Pressure is measured, and the IAT is measured to get as accurate an Air Mass reading as possible...
I guess I'm just fearing that Nissan has used a slightly inferior metering method than some other manufacturers.
