My last z32 brake question...hardware kit
frsh13
Car: 1991 240sx coupe
Well i finally got all the parts for my front 300zx brake upgrade and rear stock brake upgrade (steel lines and brembo rotors). I have one more question, do i need to order a hardware kit for the front 300zx calipers? By hardware kit i mean 4 pad pines (2 for each caliper), 2 pad pin clips (1 for each caliper), and 2 spring clips (1 for each caliper)? Btw i am using axxis ultimate brake pads so they already have the shims attached....i dont know if that matters but thought i would throw it out there.
thanx guys
Shift_Stoping Power
frsh13
bump
biggie
If everything is in working order, then you don't need it. If the stuff is broke/missing then you need it. Or is you want to feel fancy and go ahead and replace it.
hybrid_flyer
Car: 95 240sx SE wrecked....89 240 coupe now
well if the calipers dont already have the hardware then yes you will?? What size calipers did you get the 26 or the 30mm?? If you got the 30mm your stock rims might not fit, mine didn't
c-rad
Car: 1991 Nissan 240SX w/CA18DET
hell, the 26mm might not fit depending on which version of the 7-spoke alloys you have.
ILikeMy240sx
Car: SR Power
If your calipers are missing those hardware (they hold your brake pads to the calipers) then you will need them. If you got those calipers used or from a junk yard I would also rebuild them as well.
Toddles82
Car: Computers, Water Skiing, Cars
I would get it no matter what. My brother didn't and his stuff wasn't it good shape. The pin clip (long wierd metal looking thing) snapped after awhile. Plus new stuff will likely keep the caliper from chattering excessively. http://ttzd.com/
Good site about the brakes and installing pads and stuff. I always get the shim mixed up and what not. And you can use the old brake pad to push the piston back in, you don't need a C-clamp.
I bought the hardware and shim kit when I did my Z brakes.
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
If you order them from a Nissan dealer make sure you get the right quantities the first time you order. The dealer I went through couldn't seem to comprahend me needing a full set of hardware. They also got confused when I didn't know the exact year model for the twin turbo Z I wasn't ordering for. They were very sheltered.
If you go through Courtesy Nissan you shouldn't have a problem... at least from what I've heard. I'll be dealing with them the next time I need a factory or Nismo part.
Toddles82
Courtesy, in the past, had a very hard time getting orders right. I still use them tho. They've only messed up a few of my orders, but they gladly fixed each one at their cost.
frsh13
thanx for the info guys, they are 30mm aluminum calipers and i ordered them from autozone so they are already rebuilt. Im not using stock rims so i think mine will clear....if you want check out all my brake stuff in the pics below
http://photobucket.com/albums/v677/NISMOPOWER/
shift_Z brakes
yellow_jacket
Car: 95 240sx
Rebuilt calipers don't generally come with hardware. I don't ever buy from autozone, but NAPA does not include them and I can't imagine that anyone else would.
Personally I made my own caliper pins from drill rod. I think I spent a whopping $2.00 to do it.
ZULU
30MM calipers do not come in alloy , only Iron. Also if you own a S13 with stock rims you wont clear the 30 MM iron calipers. S14 16' rims will clear 30MM
sXi
30mm calipers does come with aluminum. I think it was for 91 only. correct me if im wrong but im sure it came with alum. then they changed to cast iron
spanishricer
Car: '95 240SX & '03 M45
Yes, the 30mm calipers did come in aluminum for the first 2 year models of the Z32, if I'm not mistaken...
Toddles82
http://importnut.net/300zxbrakeswap.htm
If you don't what you are saying, preface it with I'm not sure or something.
I have a set of 30mm ALUM calipers. So do alot of other people.
frsh13
Yes they do have 30mm aluminum calipers....and so im going to order the hardware kit tonight but i just want to make sure i have the numbers right
1 pad pin clip -per caliper1 spring clip -per caliper2 pad pines -per caliper
is that right?
ILikeMy240sx
Car: SR Power
if you mean 2 pad pins yes that would be correct.
Also dont forget SS lines and good brake fluid too and make sure you use flare wrench for the brake line otherwise you will strip them and say alot of F words
Toddles82
frsh13 wrote:Yes they do have 30mm aluminum calipers....and so im going to order the hardware kit tonight but i just want to make sure i have the numbers right
is that right?
you don't need the numbers. Just tell them you need a brake hardware kit for 94 300z (if you have the 30mm) or 90 300z (if you have the 26mm)
frsh13
im ordering it offline so i kinda need the numbers...but i think im right on the ones i listed above....and i already got some projectnissan stainless steal lines
Toddles82
PER CALIPER
Yes it's 2 pad pins, 1 pin spring, and 1 cross spring. The rest of that stuff is in the shim kit.
