ravera »
https://forums.nicoclub.com/ravera-u137799.html
Mon Aug 17, 2009 12:56 pm
IAT=Intake Air TempCHTS= Cylinder head temp sensorTPS=Throttle position sensor
You're also going to need MAP (manifold absolute pressure)InjectorsCoil drivers for whatever you're runningTrigger wheel, or wire the ZXT dizzy for the same purposeUEGO (Universal Exhaust Gas Oxygen) which is a wide band O2, or you'll need a narrow band O2, with the WB02 you'll need a driver to run it...
And whatever other things you plan to run (electric fan, fuel pump, boost control, etc.)
