pampadori »
https://forums.nicoclub.com/pampadori-u628.html
Sat Sep 21, 2002 9:05 pm
i have a k3t turbo. you will of course need to do a little work with the stock exhaust manifold if you want it to fit. close, but not a bolt on. you should for sure have some big injectors and pump. a nice intercooler too. nothing to big, but something front mounted. you will need a retuned ecu to run the bigger injectors. and a bigger mass air meter. with the k3t in 5th gear, from 3000 to 3500 i can boost to 10psi. very laggy if you ask me. with the nitrous on, i can get about 17psi in 5th by 3500. so maybe you will want a nice little n2o kit! i'm telling you it rids the car of lag! well, good luckshaun
