My kit, opinions and suggestions on other items
biggie
I'm putting my kit together (have been planning for a few years now), just looking for any input on this setup before I start to install (hopefully within 3 months or so- broke). I've tried to learn as much as possible (had a NA 240 for over 9 years), but still pretty dumb. Just cause I'm bored at work right now, thought I'd throw this out there.
'93 coupe, with '96 KA - 160K miles (have a backup engine waiting)
SSA new style top mount T3/T4 flangeGT32e .60/.63ebay type FMIC (need pipes)HKS SSQV38mm Tial WGS15 SR injectors (468cc)Cobra MAFJWT ECU (setup for the S15 injs and Cobra MAF)SAFC 2 for fine tuning3 inch test pipe3 inch cat-back (tanabe SMR)Autometer guages-oil pressure gauge-water temp gauge-boost gauge
Here's what I know that I still lack:custom IC pipes w/ bov flangecustom downpipecustom intake pipe and filterplanning on Greddy Profec B II and Greddy turbo timerall adapters and lines feeding turbo
Plan right now is 8-9psi on street, ability to have 10-11psi if needed. Does anyone have any suggestions or thoughts on this. Or experience with this items. Any input is greatly appreciated. It's been a long time on this project and I've not been too cheap on this project, but can't afford much more.
ThanksChad (aka biggie)
BadMojo
Car: 2007 Mazdaspeed 3
I'm not sure what a GT32E goes for, but the GT series are pretty pricey. Why not go with a cheaper T3/TO4E and a better manifold? Folks are making some really nice numbers on those.
Unless you already have the SSA, you might want consider something a bit better. As I recall, WDRacing had a top mount from SSA that had terrible workmanship.
Also, is the turbo timer really a necessity? Can't you just sit and chill in the car for a few minutes before you shut it off? You could put that $$$ towards something more worthwhile (ie. better manifold).
Also, why not just start out with just the JWT ECU and let it do it's thing for a while? You can get the SAFC2 later and get some dyno work in once the car is all sorted out.
gabossie
Car: Your mom
The newer series of SSA manifolds are supposed to be alot better, but I have yet to see any evidence of it. The only thing I would consider is that for the price of all those electronics, you could have a standalone that would do it all in one nice package.
biggie
Yes I know a lot of people still worry about the SSA manis. A guy locally that is trusted, ran demos and did all the test work on the new versions of these manis, so I went with it. And yes all of the stuff in the first list I have already purchased.
As for the just using the JWT, I know they are programmed rich, I want to be able to tune it on the dyno with the SAFC.
And yes the GT32 was pretty expensive(~700). But basically I should have a T3/T04 that spools more like a straight T3. I was looking for less lag, don't really care as much about topend power.
And the turbo timer I'm not really sure I will get, its a toss up decision and a "nice to have". Basically I'm trying to be safe and try not to harm the engine.
I got a deal on the JWT, injectors, and MAF (all for 700). Otherwise I probably would have went for some other management.
Thanks for the input guys.
