tmho »
https://forums.nicoclub.com/tmho-u32130.html
Sat Oct 01, 2005 10:34 pm
Hi Nistech,
Finally, I can take out the green shift lock controller.
Here is what I found out. From the lock controller, two wires are connected to a solenoid located near the lock cylinder. When the key is turned from off to on, the solenoid changes from retracted position to the extended position. This extended position will block the "key released button" from being depressed for removing the key. When the key is turned from on back to off position, the solenoid does not change from extended position to retracted position and so the key cannot be removed because the "key released button" is still blocked. Therefore, in this case, it may be the lock controller is not working because it does not provide a signal or voltage to make the solenoid retracts when the key is turned to off position. Or it may be the solenoid is not working because it does not retract. Then may I ask how can I know which part is not working (the lock controller or the solenoid)?
I have tried to removed the solenoid. Without the solenoid, then nothing is blocking the "key released button" and so I can remove the key when I turn the key from "on" to "off" position and depress the "key released button. Then can I just remove the solenoid permanently to solve my problem? Will there be any danger when driving without that solenoid? What is the exact function of the solenoid?
