C-Kwik wrote:I can't see all the hardware you used, but it doesn't look like any of it is of the locking variety. This includes the exhaust manifold nuts(to the head), the turbo nuts, and the wastegate bolts. For the exhaust mani and turbo nuts, I'd go to the nissan dealer and get the factory mechanical locknuts. They are the nuts for the exhaust manifold. It appears you are using a rev-hard mani, so the threading on the studs should match the Nissan exhaust mani's studs. For the wastegate, I'd use a nut designed to be used with a safety wire or a stage 8 locking bolt system. Spring washers will lose their heat treat and basically become flat washers in the first heat cycle. If the wastegate bolts come loose, the gasket will likely blow soon afterwards. I've went through about 8 wastegate gaskets myself trying to solve this problem.
I'm interested in getting some of this Stage 8 locking bolts. C-kwik, do you happen to know what thread/pitch does a Tial 35mm wastegate use? And also, what did you use for the downpipe to turbo flange? Studs and nuts? or bolts? What kind?
Sorry to ask so much, but since I'm rebuilding I wanna get rid of the exhaust mani leak recurring issue also.
