my ka24e compression results
silkk
Car: 94 B13
89 S13
07 S2000
from the fan#1 - 160#2 - 150#3 - 135#4 - 160
i'm not happy with the results :(
ELITEBB127108
you should check cylinder #3...rings might be bad or the valves...also did you do a "wet compression test?" with some oil in it? it might change the out come of the test a little bit...
Tx-Sx-FS
Car: S13 KA-T
when i did my compression for free at some local shop..i got 75 100 145 150..but thats with everything hooked up and just taking off each spark plug at a time..he did it wrong i know..but i didnt wanna say aynthing cuz it was free..but im gonna go back and tell him how to really do it..or just wait til i move..morons :)
mattdesmond
Just out of curiosity, what is the proper way to do a compression test on a KA? I have a tester but am not sure how to do it. Do you just pull all of the spark plugs and crank it?
silkk
Car: 94 B13
89 S13
07 S2000
i pulled all the spark plugs out, removed the fuse for injectors and fuel pump, and cranked 5 times.
