my ka24de is smoking.
s13zo
Car: s13 240sx
I just bought my 240sx s13 from this guy and he said it was just sitting there for a long time, when i got it the battery was dead and there were some leaks, i got all that fixed and a new battery, also the transmission slips and there is a minor cylinder rattle but he told me that when i bought it, he said it was the master cylinder. but when i gave my s13 a test drive, it began to smoke alot and it smelt like something was burnt. anybody know whats wrong?
Jaino40
Car: 1993 Nissan 240sx
Headgasket?More info please.Color of smoke?Check your oil, is it peanutbuttery?Check your radiator fluid.
s13zo
Car: s13 240sx
i havent checked the head gasket, the smoke was a blueish, the thermostat isnt working so it the water just goes right back where it came from, and the oil, it was kinda peanutbuttery i guess and it smelt kinda burned aswell.
turtle240
Car: 93 s13 koop
well when you check the headgasket checkk the head for worpage b/c its an aluminum head and in a lot of cases when the head gasket blows its b/c the head is worped i mean its not exactly cheap to get it machined but if its worped it will be better than replacing the headgasket every 2 months and you should definatley get the therm. working oem lets out at 195 and i just did mine yesterday and got a 170 for $12
but i hope every thing works out man
P.S. how much did you pay for it??
Driftlife!
Car: SR20det powered 91 240sx.... vvvrooooooooom.. psshhhh!
probably a bad piston ring or maybe several, . sounds like your burning the oil. and you have water getting in the oil as well.
mac_daddy
Car: 92 slicktop n/a
correct me if im wrong guys but i believe blue smoke means the valve guide seals are bad. gotta pull the head and replace them. mite as well do the headgasket too
s13zo
Car: s13 240sx
i only paid 600 bucks for it, needs alot of work but i have high hopes that everything will turn out great here are some pics
Barnav1t
Car: 1992 Nissan 240SX
I'm sorry... Did I read that right? You said your master cylinder was rattling? I don't know about all that, but you should definately check your muffler bearings...
s13zo
Car: s13 240sx
yeah thats what the guy was telling me when he sold it to me? i was like oookk? lol
Barnav1t
Yet you still bought a car from him. hmmm...
s13zo
Car: s13 240sx
well it was a good deal, and im looking for a project car , if this engine turns out no good ima swap out the engine with an rb25 or rb26
Barnav1t
I'm guessing that if your engine has: "peanut butter" oil, a smoking problem, and a death rattle... it is safe to assume that your engine is no good. You most likely have a blown head gasket, and bad valves, along with shot rings/ main bearings... but that rattle could be your master cylinder I guess...
Did you buy this thing from a boy racer or what? I assume th valve cover was already painted "race me red"? Not a good sign. Alot of 240's get raped over and over again thoughout their life. There is nothin wrong with a cheap, beat 240, but get ready to spend some cash... I got mine for $250, but I've got well over 6 grand into it now, and 2 years of my life.. as well as lots of dirty looks from my wife...lol
s13zo
Car: s13 240sx
well i wasnt sure about the oil being peanut butter like, ive never heard that describing oil nor have i seen it. so i wouldnt know, and the guy who had it didnt seem like a racer, as for the engine top being red, they came like that for the early s13 models i think. lol and yeah im gonna spend alot on my 240 since i want to put an rb25 or rb26 in it if the KA dies on me lol
Barnav1t
If you wanna spend money... they make an LS3 conversion for not too much more then the Skyline settup, and you would decimate all that lined up against you. Go big or go home, eh?
s13zo
Car: s13 240sx
that would be cool but im looking to stay with a nissan motor, especially a skyline engine. thats intimidating. dont get me wrong, a corvette engine is a beast lol, but like i said, i want all nissan.
s13zo
Car: s13 240sx
heres a vid of it
http://www.youtube.com/watch?v=vHlWCOtsPDs
Modified by s13zo at 2:53 PM 4/30/2009
Barnav1t
First, I'd like to say I like your initiative. Never thought of making a you tube vid to get diagnostic help. Unfortunately...that is the same sound my car made when it had a bad main bearing and a bad wrist pin. I don't know for sure which one was making the noise (I just did a whole bottom end rebuild), but both are catastrophic engine failure waiting to happen.
Second, I would stick with the KA. It is just my own opinion, but that is how I feel. I looked into the 26, and decided that it was more work than it was worth. Alot of money involved. I priced out everything I wanted and was in the 7K neighborhoood. You can turbo, supercharge, or even bore and stroke (up to 2.6l!) a KA and get a reliable 350 rwp. That is plenty for a 240, unless you are seriously racing like every other day. That can be accomplished for less than 4K.
Anyway, that is just my two cents.
s13zo
Car: s13 240sx
yeah you are right, i might just end up sticking to the KA and work from there,
Barnav1t
The KA is a greatly under-rated motor... I have a moderately built setup and it is a blast. It doesn't make massive horsepower, but it makes enough to melt the rear tires at will. The 240 is a pretty light car and very well balanced: if you build the chassis right, you don't need a ton of power to make it do what you want, when you want.
s13zo
Car: s13 240sx
ok i just found out that when i put my car on drive, it starts to smoke from the muffler and black liquid is spitting out at first but after a while it stops
MYFREE95,240SX
Car: 1995 NISSAN 240sx KA24DE 1995 NISSAN 240SX ka24de yes two of them
i watched your video and all that noise is, is your timing chain guide nissan says its ok to remove them the top one is easy just remove your valve cover and unbolt look in the fsm it shows how and search for timing chain guide noise in here
zachattack_5491
Car: Pignose S13 Redtop SR
s13zo wrote:ok i just found out that when i put my car on drive, it starts to smoke from the muffler and black liquid is spitting out at first but after a while it stops
My friend, it sounds like you have some serious work to do. That probably means you're running a rich mixture of air and fuel, all that on top of your previous descriptions sounds like some pretty major work.You might as well wait for someone to put up their old engine on craigslist and snatch that. It would probably be easier and cheaper than fixing the problems on the current engine.
