My KA24DE is Dumping RAW FUEL !!!
240sxracer20
Car: 1992 Nissan 240SX/1990 Nissan 240SX
I have a 92 240 with a KA24DE that is flooding so bad is is simply dumping raw fuel on the ground. I have already replaced the fuel rail, fuel injectors, fuel pressure regulator, Spark Plugs, Distributor Cap, both temperature sensors- I need HELP - any ideas would be appreciated
navysnail
were is the fuel coming from
240sxracer20
The fuel is coming straight out the exhaust, the pipe was wet with gas
ricebike
2002 Quest
2005 Altima
remove fuel rail w/ injectors still attached, turn key on w/out starting the vechicle... see if any fuel is leaking out of any injectors.
run some trouble codes..
recheck for spark @ each plug... recheck plug wire connections...
that's a start... check for resistance @ temp sensors/ warmer it gets, lower the resistance readings...
240sxracer20
that's a good idea, I never thought of that. That will tell me if I have fuel leaking past the O Rings won't it. Thanks
