My ka-t smokes when I stop
kat510wagon
Car runs good and boost no problem but when I stop or in idle..she's smokes.I have to rev it then it clears and no more smoke. But as soon as I drive it and boosting then go to a stop. It smokes... :frown:
So what do you guys think is the problem???.just running out of ideas.
It's a ka24de motor... Thanks guys!
moneymike
Car: 1991 nissan d21 hardbody
what color is the smoke?
kat510wagon
It's a white smoke and i can smell the burning oil..
moneymike
could be a problem with the return line or the headgasket i would lean more towards the return line though
but cant say im positive
kat510wagon
moneymike wrote:could be a problem with the return line or the headgasket i would lean more towards the return line though
Hmmm...ok I'll check on that,thanks
C-Kwik
Its likely oil leaking passed the turbine seal. Could be caused by return line issues, but can also be a seal failure. Check for shaft play....though, I had a smoking problem and it was a while before shaft play became noticable.
GEO
Car: 95 240sx KA-T
Might also be your valve seals are leaky. Does it blow any smoke out on start up from a cold start?
