Brandon93240 »
https://forums.nicoclub.com/brandon93240-u58236.html
Wed Sep 19, 2007 9:26 am
I'd go with 9 or 9.5:1 myself instead of the 8.8.(after getting ur block and head decked the 9:1 will bring u closer to factory and ur out of boost driveability will be better with a higher cr). Also is ur crank trash or something? No need for a new one unless yours is wasted(most can be repolished with new bearings and still be in spec). U don't need rod bolts either they come with the eagle rods. The cometic isn't nec needed either, u can get a felpro kit and it'll hold up just fine with the arp's. I also wouldn't get the megan manifold, to me its like having a crap load of port work and larger valves just to put stock cams back in. I'd look into the JGS manifold, not pricey at all and great quality, fitment and strength. Also u forgot an oil line kit(JGS also sell's this), a fuel pump. and what are u going to tune the 550's with? U'll also need a downpipe. Also the 50 trim loves bc stage 2 cams, at around 300 bones they are pretty cheap. Also check out ka-t.org at some members setups so u can get a better idea what ur getting into. I think I covered most the bases for you.
