My KA-T Build continues..
Nis-240sx-san
Car: 1991 Nissan 240SX KA-T
So after getting the bored, honed, and rebuilt short block from the shop, it was time for me to start the rest of the rebuild.Heres the block when I got it back from the shop.It wasn't that hard to get the block into my basement...took 3 guys and a dolly. The fun part will be getting it back up out of the basement . So after getting a little work are set up, I started the rebuild. I have been following the FSM, and a thread from ka-t.org on how to rebuild a ka24de. Both are very helpful in guiding me through my first engine rebuild. I also invested in a torque wrench, and went ahead and torqued down the head. I also decided to test mount the turbo mani, and turbo.
One thing I'm unsure about is whether to get a oil filter sandwich plate, or just run off the stock oil pressure sensor for my oil feed line? I've heard that getting the feed from the stock oil pressure location, sometimes breaks off, and can cause damage. I also have my oil pressure gauge to hook up. Has anybody had any experience with the sandwich plate? If so, was it good or bad, and which one did you buy?
Modified by Nis-240sx-san at 11:54 AM 1/19/2009
Chad4061
lookin good. what is the link you are looking at for the rebuild cause im looking to rebuild mine which is gonna be a first and i need all the help i can get! As far as the sandwich plates, ive heard that some of the will leak but ive never had any experience with them. keep up the hard work
Ekinchheng
Car: '93 Nissan 240SX Coupe
Chad4061 wrote:lookin good. what is the link you are looking at for the rebuild cause im looking to rebuild mine which is gonna be a first and i need all the help i can get! As far as the sandwich plates, ive heard that some of the will leak but ive never had any experience with them. keep up the hard work
Here's the build thread
http://www.ka-t.org/forums/viewtopic.php?t=4156
To the OP, i was wondering how much did it cost you to get it machined? I'm going the ka-t route and was wondering whats the price range. I know it depends on the shop and location but was wondering how much you paid. Also what you turbo kit your using jgs?
Chris28
Car: 92 s13 KA-T
I got mine bored .2 over, honed, and decked and it was 260. Call your machine shop and ask them though, they are going to give you an exact price, the best we can do is ballpark it.
Nis-240sx-san
yea I got mined bored .2 over, honed, decked, bottom end rebuilt, everything cleaned, valve job, port and polish done for a lil over 1000.
*edit: and yes that is the JGS kit. Overall its pretty solid. I'll see more when I get it running.
Nis-240sx-san
so I finished the engine rebuild tonight. I got a few small things to do, but now its pretty much getting the turbo stuff on the engine. Oh and is that a good spot for the oil return line? I have a spare oil pan if I did it wrong? but I'm pretty sure thats right.
xrproto07
Car: 96 S14 zenki
JGS Ka-T kit for the Win Im in the process of installing mine, just waiting for the JWT ecu tune and it'll be running wild in the streets of Dallas
aaronscomp
Car: s13
im jeolous
Nis-240sx-san
yea, I'm going to wait to turbo it until I break in the engine. its going to be a long 1000 miles!
joenismos15
Car: 1995 Nissan 240sx SE
Hows the Progress going? break in the engine yet?
Nis-240sx-san
yeah im getting there, im about 370 miles in, and no problems at all so far.
480sx
Car: 1996 Pearl White 240sx
Nice, good to hear.
oz240red
Car: 95 T3/T4 KA-T
Nice work man, If you touch up the valve cover that engine would look killer.
Nis-240sx-san
yea I was going to paint it, but I was too anxious to get the car running. I do plan on painting it though, probably around the time I turbo it.
Nis-240sx-san
Hey guys, so my engine is all broken in, and runs like a champ. Now I have all these turbo pars sitting around, all not installed yet, only because I was going to get my ECU reflashed to handle the turbo. The problem is funds are REALLY low right now, and I cant afford a reflash. So I was wondering if it would be okay for me to run low boost (3-4psi) without a reflash. I have a wideband hooked up, along with an apexi safc neo for tuning the 370cc injectors. So would this be safe to run low boost? the turbo i'm running is a turbonetics t3/t4 50 trim. Let me know what you guys think.
480sx
Nah, i wouldnt bother. Do it right or just stick N/A. SAFC as a soul tuning device is asking for a blown motor IMO.
If you really must boost now, buy a 8:1 FMU and just run your stock injectors for at max 7-8 psi. At that level you should also retard your base timing by 2 degrees or so.
Riubens
Car: ka-t 240 and 99 Q45 t
480sx wrote:Nah, i wouldnt bother. Do it right or just stick N/A. SAFC as a soul tuning device is asking for a blown motor IMO.
whoa!so you rather have a fmu than a s-afc and a wideband??that does not make sense? to the op use the s-afc and the wideband since funds are low get a knocklite and u should be straight .take it from a guy thats been turbo for going to 3 years on the afc with 525cc injectors wideband and knocklite.
oh and insted of flashing the ecu i recommend nistune or calumrt.which is my next step.
Nis-240sx-san
cool, I think i'm goping to run low boost then. Thanks for the input
