d-ta »
https://forums.nicoclub.com/d-ta-u26176.html
Mon Feb 21, 2005 12:55 pm
So after the long ordeal of trying to figure out why my KA-T wouldn't start (due to busted FPR), fixed that and now here's some more symptoms:
1. Car idles at about 1k. Before I had a problem when I turned on the lights. This caused the idle to drop and jump about sporadically. However, it seems to have gone away. On the other hand, once I rev the car and let go of the gas, the rpm just drops and I stall.
2. Thick white smoke. Burning coolant from what I've read up on, but I'm not sure as to where it's coming from besides maybe a blown headgasket?
3. Car runs rich. Smells like gas and spark plugs are black and smell like fuel. I replaced the coolant temp sensor today and didn't notice a difference so I'm assuming this might be from my bad o2 sensor.
now here's the ecu codes from my check engine light:
1. ECU Code 12 (MAF)
I just checked the ecu codes again today and this one suddenly came up out of nowhere. Not sure what's up with it. Should I just get a new maf, clean the maf, or check the wiring?
2. ECU Code 25 (IACV)
I cleaned the IACV per these instructions and I'm still throwing this code. The only thing is that I wasn't able to get the engine to warm up to operating temperatures when I did it. I had the car idle for 15+ minutes and the needle barely moved above the lowest mark on the temp gauge.
3. ECU Code 33 (Front o2 Sensor)
Getting a new Bosch one with OEM plug in sometime this week. Hope it solves the running rich problem.
Alright and just to give you some background, here's my setup:
T3 super 60JGS Tools log manifoldModified NPR FMIC1g DSM BOVSR 370cc InjectorsJWT ECU programmed for 370cc Inj and Stock S14 MAF3" downpipe, testpipe, and exhaust
It's been several weeks since I've driven my car and bumming rides or borrowing cars to get to school and work hasn't been very convenient so if anyone can offer any advice, I'd greatly appreciate it. Yeah, I admit I'm definitely a retard for having done this to my daily driver, but I really didn't expect it to give me so many problems. I can say that I was frustrated to the point where I was considering converting it back to stock, parting it out, and selling the car. But now it seems like I can almost see "the light at the end of the tunnel" so I'm gonna try to stick it out till it works. Once again, thanks for the help!
Modified by d-ta at 10:54 PM 2/27/2005
