my KA makes flesh crawling sound when starting
jismo
Car: flat red 93 240sx
my ka makes this bad grinding noise when it is going into its compressionstroke when starting but in exhaust stroke sounds like a normal kamotors not locked. can anyone help me and tell what that is? warped crankshaft? bad main bearings? or has my Ka just give up on me
i buy the car with the motor in it so i dont know history on how the guy treated it ,but i did have to put a oil pan gasket on it (really bad oil).
nissan2.4
Car: 91 240SX hatch N/A KA
brian crower stage 2 cams
obx headers
custom cold air intake
removed cat, egr valve, anti swirl valves
What happened before all this? Did it die on you? Or you just got up one morning and it started doing that? Does it run?
jismo
no see i heard this sound when i got the car running when i first buy the car it was not running when i buy it. i though the flywheel what just damage or teeth missing off it .i though if i just replace it it would stop. it ran before i had to put a headG on it.guy sold the car because he though the motor was locked upi turned the crank by hand not locked up he was just hearing this grindingnoise that im hearing thinkin it was locked up
nissan2.4
obx headers
Well since its not running first thing i would do is do a compression test. If its ok, check fuel pressure. Remember, for an engine to run you need to have compression, spark, and fuel. Make sure you have spark. If you have fuel pressure, spark, and compression get a hold of a noid light to see if ur injectors are firing. Lemme know what you find out.
