my KA lags a little bit off and on
hkssupratt1994
Car: 92 240sx hatch
its had a tune up and sometimes it feels weak and then after another 20 minutes of driving it and it pulls so much harder what could this be?heatsoaking maybe?i have a new fuel pump fuel filter plugs air filter fresh coolant.plugs are a little white and greyish color if this is any help
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
im guessing your rocking a walbro? what are you using for a tune? white=lean right? what do you gap your plugs to?
ArticDragon192
Car: 91 Z32 2+2
Time for a new O2 sensor. I car would do the same hing when it was cold. Once it warmed iup it would go away. A new O2 sensor fixed the problem.
hkssupratt1994
Car: 92 240sx hatch
it doesnt do it untill i have been driving it a while you think its the o2 sensor?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
im really leaning towards MAF. normally lack of power is from either CTS or MAF.
usually not o2, because at WOT o2 is ignored, or we wouldnt run so damn rich...
so give it a clean i guess or borrow a friends if possible.
hkssupratt1994
Car: 92 240sx hatch
i doubt theres anything wrong with my MAF but the car has 200+ thousand miles on it, it could be the cts you think i should go buy a new one?
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
a lot of people drive around with bad CTS's, but they are so cheap its worth buying another one.
this is kinda how my bad cts started out, but eventually it gets so bad there is always a power loss until 5300 rpm at WOT.
to check it you could either check its resistance values against the FSM, but you need a gauge to tell you the exact temp. otherwise, unplug the CTS and see how the car acts once its warmed up, and then compare it to how it acts with it plugged in.
check the tps so see thats in spec, but i would at a minimum clean the maf. CRC makes maf cleaner now that i wanna try....
i might get a new one especially if your CTS sensor is still red, its gotta be pretty damn old. they've been blue for a few years now.
hkssupratt1994
Car: 92 240sx hatch
i just bought a new one and put it in it was only 25 bucks plus the senor prob is bigger
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
well i also dont see why you only took my advice, because a new bosch o2 sensor, get the universal one, is only around 25 bucks, sometimes less.
so thats a good thing to grab too, but let us know how the cts turns out.
93HATCH240
Car: 1993 NISSAN 240SX HATCH
Where exactly is the cts located? I'm beginning to think mine is faulty.
hkssupratt1994
Car: 92 240sx hatch
mine was cause my car starts better but it idles like 200 rpm more but you know where the top rad hose is clamps onto the block where the air bleed screw is,there to senors on the side of that facing the fan the big red one closet to the battery is the one for the ecu the other one is for the gauge.i got mine at pep boys for 25 bucks and its was black and a little bigger but it fits fine and my cars pulls harder sense i put it in
lbrowne
CTS is cheap and super easy to swap. Check your injectors - I just found out today I have a leaky one.
Also, check your intake piping, on my first 240 the rubber section directly off the throttle body had cracks in it underneath, so you wouldn't see it from just looking at it. Made my idle go really low etc because unmetered air was getting in.
Also check your EGR if you still have it, is it clogged? Most remove it rather than freshin the system. (I still have mine)
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
cts is the red, or i guess blue or black, sensor on the upper intake manifold by the water outlet. its the larger one, not the smaller one.
hkssupratt1994
Car: 92 240sx hatch
mine old one was red the new one was black and bigger it made a difference but i still dont know whats making it idle high .EGR wheres that at?
hkssupratt1994
Car: 92 240sx hatch
is it that black box beside the intake and exhaust manifold?i have it disconnected where it goes back into the intake,is that whats causing it to idle high?its at like 900 it should be less than 800 rpm
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
if you didnt plug everything back up you'll definately have an idling problem, thats for sure.
hkssupratt1994
Car: 92 240sx hatch
the harness fit on fine on the senors and the little metal clip went on fine as long as the harness is all the way on the senor is fine right and how many quarts does an s13 transmission take i put 2 and a half in it
