my ka isnt starting
Denko44
hi, i have a kade in my s13 and a while ago it stopped starting. It just cranks but doesnt fire up. Here is what i already did,- checked ecu for codes, ecu didnt throw any-car gets fuel-gets spark,-cleaned the mafWhat else should i check for? any help will be appreciated.
Denko44
little update, i check the spark plugs and they are really black, car running rich im assuming, and i got the car to start up just a few mins ago, my dad took it out for a spin and the ***** stalled now he's trying to get it running again... looks like fuel pump issues
ZOMG.SR20
Car: 1990 s13
knock sensor replace it then get back too me
Denko44
ZOMG.SR20
Car: 1990 s13
was there a need to type that twice im telling you its the detonation sensor not asking anymore its nothing to do with fuel pump or injectors
lil_john84
Car: 1992 240sx
i am having the same problem...i think i have figured mine out tho. it seams like my o2 sensor is messed up causing it to run rich. check the o2 sensor wire and see if it is exposed and could have touched a ground. this could have caused it to burn out the signal to the ecu....and now the computer can not detect that there is to much fuel in the exhaust. to start the car back up when it stalls, just hold down on the gas pedal and crank till it starts...this will allow air to get into the motor and evap. the gas.
how is the idol on the car when it runs???
well try and check that out and let me know i can try and help some more after that.
good luck
