My J30's power steering is acting crazy
nkawall
Car: 93'Infiniti J30 & 09 Altima Coupe 2.5
Hey , i have a 93 infiniti j30 and it runs great with no problems...until now...my power steering has been very heavy for the past few months...when im driving it is on and off ( free then stiff) and yesterday and the day before it was free as a bird... but i think it was only because the temperature outside was over 32 degrees celcius... i really need help on this ...i know it cant be the pump if it suddenly started working again...its not the fluid...WHAT CAN IT BE???please help me
driverdriver
Car: NICO's longtime resident Canuck!!!
I would hazard an educated guess that your power steering pump is on the way to failing with or without a leak.
nkawall
is there a possibility that it could be the power steering solenoid?
driverdriver
Its possible. I think the solenoid throws a code. Do you have HICAS?
nkawall
but you could be right because its a 93 and i am the original owner of the car since it was new and i never changed the power steering pump ...so i guess its about time
nkawall
it's a 1993 J30 not the touring version so i dont have HICAS
gr8scott72
Car: 1994 Infiniti J30t
Before you go throwing money at it for a pump replacement, buy a bottle lucas power steering treatment and see what that does for you. It's good stuff and is only a few dollars.
Get a turkey baster and get out as much of the old fluid that you can and then add the Lucas.
nkawall
just take as much as i can out of the reservoir then fill it with the lucas ?
gr8scott72
nkawall wrote:just take as much as i can out of the reservoir then fill it with the lucas ?
Bingo.
And the Lucas is very thick so it will take awhile for it to circulate through the system. (Day or two.)
nkawall
k i'll do that tomorrow and i'll get back to you with a result in a few daysthanks for the suggestions bro
gr8scott72
np, let us know how it goes. I've saved several Fords with a bottle of Lucas.
nkawall
Check out my car and tell me what you think
http://www.cardomain.com/ride/2106414
VG30DE
Car: 1993 Infiniti J30
Car looks great.
How did the power steering problem work out?
nkawall
i put in the lucas this morning and its still the same...i'll drive it around some more and get back to you later on tonight if it gets any free-er
fourdrinie
Car: 2019 Q50
I would loosen the power steering belt and see if the pulley moves freely...the bearing in the pulley may be shot...
gr8scott72
fourdrinie wrote:I would loosen the power steering belt and see if the pulley moves freely...the bearing in the pulley may be shot...
If the pulley is shot I would think you'd just get a squealing belt.
NismoChi
Car: 94 J30
If Lacus doesn't work , you are more than likely going to need to replace the pump.
nkawall
that lucas didnt do a damn thingso i guess it has to be the pump
gr8scott72
nkawall wrote:that lucas didnt do a damn thingso i guess it has to be the pump
[SARCASM]Well geez, it's only a 15 year old car. I can't imagine why the power steering pump failed in that short time. [/SARCASM]
nkawall
LMAO(Sarcasm)I KNOW EH
I WONDER WTF HAPPENED...I THOUGHT THIS STUFF HAD A LIFETIME GUARANTEE(Sarcasm)
nkawall
alright guys...i waited a few days for the lucas to work in and now it seems that it has saved me from changing the pump because its free as a bird now...thanks for the advice
gr8scott72
Told ya it was good stuff!!
Glad it worked out for you.
nkawall
OMFG...ok now this is starting to piss me off..today i went out and left my car in the parking lot of the mall...when i came back the car was burning hot because of the sun and then i started the car...and the friggin power steering was heavy AGAINNN!!!hellpppp meeeeeee
