carlos_knology »
https://forums.nicoclub.com/carlos-knology-u278.html
Sat Feb 15, 2003 7:05 pm
In case you may have missed it, I had started a thread called "Sometimes I hate my J30". In that thread I talked about the fact that I've had to replace my power window regulators several times. In the middle of that rant, I mentioned that I was worried my sunroon would go out next.
Hence this thread. Tonight, my sunroof DID BREAK!!!! It will open but when I try to close it, the sunroof door binds on the passenger side and it won't close. I was able to close it by holding the switch in the close position while applying pressure to the side that's binding ARGH!!! Sooooooooooooo, I came straight to NICO to do a search on the topic.
The good news is that the repair kit is only about $40. The bad news is that it appears to be A TON OF WORK! I found this thread with detailed instructions on how do go about it.
http://www.nissaninfiniticlub....nroof
The question is, is this really a DIY job? Sounds VERY involved. Have any of you taken on this job?
Carlos
