95J30tBGGUY »
https://forums.nicoclub.com/95j30tbgguy-u91316.html
Thu Jul 02, 2009 4:17 pm
I got the same problem. It has power cause all lights inside the car and on my dash works. As well it makes the "chak" noise or sort of but it won't start. So what I did is I open the fuse/relay box under the hood follow the diagram on the lid and there is a little black relay that is for STARTER HOLD and mine was bad. I went to the junkyard and get one for $4. And now it works wike a charm. Also you can try the blue one for the STARTER. Try swithcing the blue one next to the little black one (I think that one was for the heated mirrors) with the blue one for the starter and if doen't work go get the little black plus some of the blue one in any case.
I hope it works for you as it worked for me.Good Luck.
P.S. I also got a question If the same persist after the new relays in my case where should I start looking for the problem the starter it self ? Thanks guys you're the best
