My iPhone integration...
EricBss7
Car: 2009 Nissan Rogue S
Decided that I wanted to start using my iPhone as a music source instead of my iPod. The dock for the iPhone is great because it allows for an aux output in the back. I mounted the dock in the massive hole with velcro, and connected a car charger for the iPhone to the power source in the hole. The aux cord was the tricky one because it's pretty obvious there's really no easy way around sticking it in the front of the radio. I did manage to route the wire up and over the folding door, and it still closes and looks fairly clean when closed. The wires behind the dock need some cleaning up, but it's really not as bad as it looks, especially not from the driver seat perspective.
Door Closed
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
maybe you should consider getting a black cable instead of the white one... i think it would look a bit cleaner like that
EricBss7
rjdmmfl1 wrote:maybe you should consider getting a black cable instead of the white one... i think it would look a bit cleaner like that
I agree and most likely will...but I had this one laying around and just threw this together quick...thanks for the opinion
LegendRacer
pictures? is it me or i cant see ur pictures?
EricBss7
LegendRacer wrote:pictures? is it me or i cant see ur pictures?
might be you...i can still see them..
notaverage
Car: Altima Coupe 3.5 SE w/ tech pkg and VDC. Precision Grey
I can't see them either, lol. I think it's because I'm at work and my work has the website hosting the images black-listed. If you are viewing this thread from work, it may be the same problem
CraigDaModeler
Car: 08 Coupe
Black cable for sure, also one with a 90 degree plug will hold it a bit closer to the console.Nice clean fit in the "hole"
