mr_wizard wrote:I've read SEVERAL resources on how a turbo works exactly. This is my interpretation of how it works, please tell me if it's right.
When a car accelerates, obviously it produces exhaust. With a turbo setup, when that exhaust leaves the motor and goes into the exhaust manifold, the turbo (or turbine) attached to it spins up, thus the compressor attached by the spinning shaft also spins up and causes a compression of the air (the remaining exhaust goes down the downpipe and out the exhaust). Now, since the air is hot from all of this, that compressed air needs to go from the compressor straight through an Intercooler (which I use to think was the same thing as a radiator, guess I was wrong), which is basically an add-on to the radiator (the intercooler cools the compressed air and sits behind the radiator). And from there, I don't know.
I'm a bit confused as to how your describing it. Almost sounds like you are thinking the exhaust gasses are compressed and put back through the intake. If you are, then it's wrong. If not, then this is just clarification. The intercooler is designed to cool the compressed intake air as compressing air increases it's temperature. Cooling it gives you denser air(more oxygen) and helps reduce the propensity for a mixture to detonate.
mr_wizard wrote:Where does that compressed cooled air go? Does it somehow connect to the side of your intake, that then goes to your motor somewhere, or what?
The compressor is actually going to be in the intake stream. The intake piping between the compressor and the intake manifold must be essentially sealed so that the pressure does not escape.
mr_wizard wrote:Also, the wastegate is also called a "BOV" right? I know a waste gate opens up and lets some of the exhaust back-pressure bypass the turbo and into the catback exhaust after there's too much boost going into the turbo to prevent it from over boosting.
Wastegate and BOV are very different. A wastegate is designed to control boost by diverting air around the turbine as you reach a set boost level. Without it, a turbo will continue to increase boost level until something gives or the engine can no longer put out anymore airflow through the turbine. On any typical turbo, this will likely be well beyond any safe boost level for a typical motor. A BOV or blow-off valve is a device that lets air out of the pressurized intake piping when you close the throttle under boost. This is to prevent compressor surge. Surge occurs when there is too much pressure and not enough airflow. This can seriously damage the turbo if it is too severe or occurs too much. The BOV also opens(perhaps partially) during part throttle when vacuum is present in the manifold and pressure in the intake. It is also preventing surge during this time. While you can control boost with a BOV-like device, it's not recommended. A wastegate works by allowing the turbo to extract only as much power as needed to produce the boost and airflow the motor needs. Releasing intake air as a method of reducing boost means the turbine is actually using all the energy it can out of the exhaust. This means higher backpressure than is needed for the boost and airlfow you want. It would also cause less efficient air compression as the compressor would heat the air as such as it needs to produce the actual boost produces at the compressor. Some of the heat would be lost as the pressure is released, being that the compressing process is not 100% as it is, you'ld end up ultimately with more heat than is needed(more work for the intercooler). It would also make turbo sizing much more complicated as well as you'lds need to maximize efficiency for a turbo that is not wastegated. The short of it is, don't bother with boost control methods that work on the intake.
mr_wizard wrote:Few other facts I know. Since more air molecules are being force inducted into your motor, the motor needs more fuel. Sometimes, if the boost is high enough, you will need better fuel injectors.
Not necessarily better, but perhaps bigger. Just need to make sure you can provide enough fuel. You'll also need a way to control or compensate for the larger injectors(remapped ECU, stand-alone ECU, piggy-back ECU, hacked MAF. On a KA, you'll be getting real lean beyond 4-5 psi with stock injectors.
mr_wizard wrote:So off the top of my head, pieces needed for say a 10 psi turbo set up are:
Turbo compressorTurbo turbineexhaust manifold that will fit your turbointercoolerpiping from compressor to intercoolerpiping from intercooler to....?wastegate or BOV to release pressurefuel injectors if you have high boostboost gauges if you want, but not necessary
Thanks for all your help guys. I'm doing a turbo setup in the near future, I'm just hoping I can learn exactly how it works so maybe I can do it myself rather than pay someone 500+ to install and tune it.
Turbo(turbine and compressor are part of the same unit)Manifold that will fit yor motor and turboFMU or larger injectors with approprtiate compensations for the larger injectors.Piping from turbo to intercoolr then from intercooler to throttle body.Wastegate 'and' BOVoil lines to and from turbo.
this is a bit rushed as I have to get going. If you have questions, ask away and either I or any of the other knoledgable people here will answer...
