Z31toZ32 »
https://forums.nicoclub.com/z31toz32-u97552.html
Mon Aug 16, 2010 7:07 pm
i'd consider doing the re furbbed injectors only if you intend to ditch the car in 2-3 years or less. if your plans are longer term, chances are since one has gone, the other ones have been over worked and will soon fail one after the other. if the case is long term for the car, just go with all "new style" injectors. the old injectors had a few flaws, number one being that current is always running through them when a battery is hooked up. this is led to the injector coil wire prematurely shorting out, and 2, the addition of oxidizing additives to fuel lead to deterioration of the wire coating again leading to a short out of the coil wire. new style injectors do not have these problems, but you will need a fuel rail adapter to use the new style. not really a problem. as far as the plenum goes, some injectors do not require it to be pulled, while some require it to be pulled. on the one required to pull the plenum, you can actually grind down the plenum with a dremel tool so that the injector has enough room to be pulled out. this is a "hot" arguement, as many people consider the dremel method as a cheap shortcut. at the same time, the dremel method is in the nissan tsb, and is a published proceedure. so, your call. i bet if you didnt do the dremel and that injector failed again you would curse to no end, where if it was dremmeled it would be a 10 minute change.
