Ezzo »
https://forums.nicoclub.com/ezzo-u38172.html
Fri Mar 24, 2006 1:13 pm
ok good news and bad news....
i got started today, pulled the injector, dumped the oil, changed the filter. sucked all of the gas from the cillinder. put a cap full of oil in each cillinder to try and reseal the washed piston rings. put the new injector in with new o-rings.
get in, turn the key, the engine cranks freely now but it wont turn over. checked all of the plugs, wires, made sure we had the correct firing order. couldent figure it out, get back in try to crank it again, it starts to crank really slow now and the cluster lights dim (seatbelt, oil, check eng ect) still can't get it to turn over. i pulled out the dip stick and the new oil looks thin and still smells like gas, i think that the rings are still washed, or i couldent get all of the bad oil out. im about to take it to a mechanic and have them flush the engine if i cant figure this out. No compression from washed rings? the car sat with gas in the oil since monday. its friday now.
any sugestions would be appriciated
