PROBLEMEDINFINITIQ45 wrote:.... IF I TURN THE KEY TO THE ON POSITION AND RUN POWER TO THE STARTER IT WILL TURN OVER. WHAT IS MY NEXT STEP?
Will the engine start and run after the starter has been jumpered? Or just turn over and try to start? How new is the battery? What happens with a battery jump from another vehicle?
My next step would be to examine both battery clamps. Is there any corrosion on the battery terminals (clean with baking soda/water)? Are the battery clamps still in good shape? Are you having trouble getting either clamp tight? Bad contact or a clamp that's not quite tight at the battery can cause your problems.
Hold off on buying a new distributor (aka CAS- crank angle sensor) for now.
