Firewind »
https://forums.nicoclub.com/firewind-u40995.html
Sun Dec 21, 2008 8:09 am
My 91 has the same problem. Some times if I hit some bumpy roads the keys just fall right out onto the floor.
However, on the S13 models (unsure about the S14) there is a button you are suppose to press when taking the keys out.. the key lock button, but of course the keys just come right out. So you can take the keys out before you should. Be aware of this because if you don't turn the keys all the way back and press the button, you can take the keys out, and then start your car with anything. You'll often here a little ping-pong warning as if you left your lights on if you do this, because your car, and slut like ignition still thinks you have a key in her.
