Alright, I’ve had some changes come about.
My HTPC is up and running just fine! I have a 38.3GB .ts file of Avatar (34mbps avg bitrate) and it plays awesome thanks to TMT3 with hardware acceleration enabled. I have a thread about the software here.
movie-playing-software-for-pc-s-t492236.html
The matching Infinity Beta-c360 center is too small. The wife doesn’t want the TV sitting on the speaker that either isn’t as wide as the TV or TV stand. It looks kind of silly having a 54” tv sitting on a speaker that is only around 2ft wide. So the wife said I must go bigger!
Well I finally found a center that will work for me, so long as I modify the design a little, i.e. make it wider. It’s a DIY kit that comes with the drivers and crossover. The enclosure and everything that goes into creating an enclosure is up to the buyer. There are certain guidelines that must be met, for example, driver spacing, location, and baffle height must be kept the same. Enclosure width, depth, and volume can be changed within reason. My wife’s friend has a cabinetry shop with a 3-axis CNC machine, so I’m trying to work with him on getting an awesome enclosure built, but right now he’s having software issues. Who knows when I’ll be able to start building the enclosure?
These are NOT my speakers, but is a shot of the finished kits so you can get an idea on how big the center is. The center pictured is around 43" wide, but I will have to make it a tad over 4ft according to my wife, then mount the TV to the wall.
http://clearwave.forumotion.net/cld-bui ... ild-t5.htm
This brings me to my next change. Since I am going with a completely different center, my other speakers need to match it, so I will be getting new L/R’s later after completing my center channel build. And I am also going to be gone for a year or so for military stuff so I am selling pretty much everything I have audio wise and will start all over again when I get back; sans center, sub amp and pre/pro, and a few other things.
I already sold my 2, 15" woofers I was going to use for my previous speaker build and also one of my 15" subwoofers. I still have my 4, 12" subwoofers I was going to use for my "swimming pool" build that I'm now not going to do. (gotta have bass for pool parties right!
) I'm going to try to sell those too, but if they don't, I'll keep them to use in my HT.
The 4, 12's are on the right hand side. 15" woofers in the middle, 15" subs on the left.
