My Home Made Resistor box :)
S13FX
Car: '69 l20b Dimeski :)
Hey guys so I got my 370cc CA injectors YAY heh. And I am in the process of designing a resistor box here is a picture of my lil set up so far, and for any one electronicly inclined can u tell me if Im using the proper resistors?
thank you
maik21
Car: 90 Nissan 240SX Coupe 5.0
if you do that..... emm... its suposet that the resistance of each one is 10 ohms... if you conect this to the inyectors... it will be...."resistante 10 ohms" plus "resistance injector"i think you need at least... 5 watts resistance... because the current of injectors work !!!
i do not what value you need... but i know that you need at least 5 watts resistance to prevent danger to the resistance and injectors =)) good luck
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
maik21 wrote:if you do that..... emm... its suposet that the resistance of each one is 10 ohms... if you conect this to the inyectors... it will be...."resistante 10 ohms" plus "resistance injector"i think you need at least... 5 watts resistance... because the current of injectors work !!!
had to quote before he is sober and ... boy did that make a lot of sence
veilside180sx
Actually the injector wants a 12-16 ohm load. Just pick up 10 ohm 10 watt resistors from radioshack. Can't think of the part number off the top of my head, but they are in the parts drawers and only like $3 for 4.
maik21
Warped wrote:had to quote before he is sober and ... boy did that make a lot of sence
sorry =(
Warped
lol all in fun ... were you drunk ?
maik21
hahahahaa , nop .. not today =) , yes tomorrow =)
kapower06
the part number for the resistors are 271-132 from radio shack... glad to hear that they made it there on time. thanks - Jake
