Are you judging by size or brand? Is Greddy bad?sepulchralx wrote:thats a s***ty wastegate, you should really get a 50mm or 60mm
Wow, not everyone has the cash to drop on a lovefab manifold that doesn't fit.sepulchralx wrote:thats some messy as fabbing, as long as its functional i guess.
I am almost sure i put something in there about no comments about the welds on the dump... I would love to see what you can do with a 110 flux core welder and a 10x20 garage... Anyway I have not really heard much bad about ssac wastegates... i got it for 40.00 from a friend and will get a better one some day but so far so good!My goal is 350-400hp so a 38mm will work fine.And the pcv hose now has heat wrap on it... ordered some steel braided too... should work till i redo my pcv system.You will have to cut the lower heat sheild bolt mount off to fit the compressor. I had to use 2 1/2" flanges to fit mine it wouldnt fit with just one... not sure about the HX35Thanks for all the comments...sepulchralx wrote:thats some messy as fabbing, as long as its functional i guess.
Well good luck... i hope you dont have boost creep and expect some quick response with your stock manifold (good low end... not so sure about your top end )Nissan2367 wrote:I think the one i used was a Harbor Freight but i was impressed on how well it worked! Its not a show car so it works! Its all together and runs awesome! I watched and full 8-9 psi hits at 3500. Thats awesome to me! Next i need injectors and a tune then 400-450 here i come!
Totally correct.rcrdps wrote:One thing I've read about wastegates: Bigger isn't always better. If you're running high boost, you don't need to limit your turbo as much, so you can run a smaller wastegate.
I guess it's one of those things that "just depends" on the setup. If he's not creeping right now at 8psi, he probably won't have a problem further up.
Gene
I tried fitting my HX35 up last night. Looks like it's the same. To route the compressor outlet up like you have it, I'd need another spacer. I might try routing it down. I saw where someone did that. It will fit with one spacer that way. Might be hard to route the intake tubing though. There are a bunch of lines down there.Nissan2367 wrote:You will have to cut the lower heat sheild bolt mount off to fit the compressor. I had to use 2 1/2" flanges to fit mine it wouldnt fit with just one... not sure about the HX35
Stock header is cast.xibeacx wrote:are you sure that stock header isnt it galvanized?.and arent those plates metal?.how are they supost to stick, even though it sticks after a while wont it brake off??.
or i might be wrong
