AxiOn419 »
https://forums.nicoclub.com/axion419-u32499.html
Mon Dec 10, 2007 2:41 pm
Ahh, where is the diligence man. You will get the thing running right. Your problem could be something simple. Also, this may not be as bad as you think. Your whole ignitor may have just givin out. Not a huge deal. Check the resistance between the pins on the ignitor with a voltmeter. Go from pin 1 to pin 1 on the other side, then pin 2 to 2 ... See what it reads.
Also, you can check to see if you ECU is giving spark by sticking the positive probe into the plug that connects to the ignitor. Unhook the ignitor on the left side (if you are facing the front of the engine bay). Stick the positive probe into the metal prong of the harness that is associated with the #1 spot on the ignitor, do so for all 6. Make sure to ground the black probe on the chassis before doing this. Have someone crank the car over (it wont start, the ignitor is unplugged) and see if you are getting a signal. You want the voltmeter set on AC current for this test. You will see the number bouncing up then down, thats normal because its sent as a pulse. Just make sure you are getting signal across all 6.
Dont give up
Also, If it is the ignitor then dont stress out.. I do have a spare that I suppose I am willing to part with if it means another RB will be up and on the road. They are not that expensive.
Modified by AxiOn419 at 4:57 PM 12/10/2007
