curtiscr87 wrote:anyone having the same problems? it blows cold air unless im driving it and then its not even that warm. If i just sit there with the engine running it doesnt get warm at all
You did not mention if your engine is operating at temperature? If so then you may have a plugged heater core. Before you panic if that is the case you may get away with backflushing the heater. Another possibility that I am not sure if it exists is a malfunctioning temperature control valve. On some of my previous cars water flow was through the radiator if the thermostat was open, through the heater if the temperature control valve is open, or bypassing both flowing only through the engine.
Like I said, not sure if this even exists on the Gs.
Perry
