My hand Brake is loose need HELP!
QX4kid
Car: 2000 Infiniti Qx4, 2003 Infiniti G35
I got back from work and i noticed that me hand brake is very loose. it feels like there is a loose bolt when i lift it. How do I fix this problem.
Pwnin O'Brien
There's a specific process listed in the FSM for this (like pressing the brakes, pull up the handbrake five clicks or something like that) but it's really simple to do. If you look under the handbrake (behind the plastic flaps on either side of the handle, you may have to remove that small trim piece at the base of those plastic flap things) there is a bolt which you can tighten until the handbrake is tight again.
