my goofy 240sx
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
for some odd reason, my 240 has been weird symptoms: idle fluctuates from 500 to 1200 rpm, gears shift really hard in 1st and 2nd. when i let off the gas, it seems to be stuck in a gear so it seems like its in neutral-revs drop to 700ish rpm. a grinding noise has appeared when in reverse. its an automatic. im assuming i need a transmission flush, but the idle problem is perplexing...
dickie
Car: Killer Turtle
moved to tech forum.
yangs13
bump
Fla240sx
sounds like a transmission problem
don't recromend a flush
going to need a new transmission soon... really wierd it has a grinding sound going into reverse.... your completely stopped when you go into reverse?
your transmission should have a drain plug on the bottom of the pan, just take that out and when its done draining put it back and fill with new fluid
mercon/dexron III is what you want, and you will need 3-4 quarts if you don't have any leaks...
check fluid level in Park, after refilling, start car, put gear selector in each position for 3 seconds going from P-R-N-D-2-L-2-D-N-R-P and leave car running, take out dipstick, whipe clean, re insert, take out and notice fluid level... add in 1/4 quart amounts as nessecary... and if its not on the stick at all add another quart and continue the process....
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
5 speed swap ftw.... autos suck unless your making a drag car, then some ppl still like stick better.
yangs13
i am at a full stop when i reverse, its usually backing out of my driveway. ill change the fluid and see what happens from there
